It is currently Tue Aug 12, 2025 9:55 pm
 Post subject: First Radial rosette.
PostPosted: Fri May 06, 2016 3:24 pm
Though I'd try a radial rosette for the first time.
Client said he had some Plum wood and could I use it for the rosette.
Turned out to be a few thickish branches from a local tree growing in a wall, cut down by the local Laird which said clients Wife had aquired.
One log he'd tried to help (bless) by drying it out, putting it next to the wood stove for a month or so (split everywhere of course)
Another other chunk he brought was rotten in the middle (lying in a field for a several years), but I managed to salvage enough for this.
I do like the wood, subtle, with pink/lavender/purple hues in it.
I still have to level everything, just waiting for the glue to dry.
PostPosted: Fri May 06, 2016 3:27 pm
Last Name: Sollod
Looks great! I like it.
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: Colin North (Fri May 06, 2016 3:35 pm)
PostPosted: Fri May 06, 2016 3:47 pm
Looks good Colin. Nice and mellow.
These users thanked the author SteveSmith for the post: Colin North (Fri May 06, 2016 3:52 pm)
PostPosted: Fri May 06, 2016 6:29 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
That looks really nice, Colin! Should have some pop when the finish goes on!
I did a book matched end grain olive wood, for my #2 in progress.
Alex
These users thanked the author Alex Kleon for the post: Colin North (Sat May 07, 2016 11:45 am)
PostPosted: Fri May 06, 2016 7:03 pm
First name: Brad
Last Name: Combs
Looks great!
These users thanked the author bcombs510 for the post: Colin North (Sat May 07, 2016 11:45 am)
PostPosted: Fri May 06, 2016 8:14 pm
Last Name: Beaver
City: Lake Forest
I like it Colin!!! Good job all around
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Colin North (Sat May 07, 2016 11:45 am)
PostPosted: Mon May 09, 2016 1:37 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Looks great !
Nice top also.
Mike Collins
These users thanked the author Mike Collins for the post: Colin North (Mon May 09, 2016 1:49 pm)
PostPosted: Mon May 09, 2016 4:48 pm
First name: Alex
Last Name: Kleon
City: Whitby
Colin, would you mind sharing our process? Your work looks nice and clean!
Alex
These users thanked the author Alex Kleon for the post: Colin North (Tue May 10, 2016 2:21 am)
PostPosted: Tue May 10, 2016 2:15 am
No worries Alex, nothing proprietary, got the general procedure from OLF, Burton LeGeyt and Todd Stock IIRC.
Made some wedges at 2mm thick on a small shooting board set at 22.5 degrees and superglued (thin CA) them to a 0.8 mm (1/32") square ply backing board double taped to a formica laminate board, cleaning off any excess CA with acetone.
Adjusted the last 2 wedges at the top for any cumulative error in the angles.
Then thicknessed the assembly on a 10-20 drum sander to 1.8mm and cut the rosette out with a wells-carol circle cutter. (target thickness for the top was 3.0mm)
Removed carefully with Naptha (messy!) and cleaned up.
Glued this into a channel cut in the soundboard (thickness set with the excess rosette material), left overnight to dry.
Channels for the purfling were cut with a bit the same size as the purfling.
The back edges of the purfling were bevelled, it was formed to diameter in steam, then tapped in with a small hammer.
Excess purfling levelled with a block plane, dried overnight, soundboard run through the 10-20 to level and clean-up, final thicknessing done on the back.
All bits used were downcut spirals (1/4" and 1.3mm), TB glue was used on the soundboard channels, sealed with 1lb cut shellac.
Users browsing this forum: Gasawdust and 36 guests
